2011 Truck 5.0, Boss 302 intake
Discussion in 'COMP Cams Support Forum' started by eighty6gt, Feb 2, 2019.
  1. eighty6gt
    eighty6gt New Member
    Apr 7, 2015
    I am starting a new project, trying to figure out a driveline and can get my hands on a 2011 truck 5.0 that the intake valves are going on. I would install the later valves and get a valve job, repairing the heads. I can install any springs I'd like at this time, and would do the usual oil cooler delete, oil pump improvements.
    If I wanted to max out the benefits of a Boss 302 intake and full exhaust, what Coyote cam setup would be the best? I can clearance the head casting as required. This is not a daily driver, will be an off road racing car and milk run mobile. I want to hear it chop at idle and wind out to high rpm, make 500+. Trans will be a face plated manual.
    Thanks!
    ** alternatively, if I find the heads to be too expensive to repair It appears I can purchase some 2015 heads from Ford for about $1000/pair plus core. Let me know if this changes anything.
    I would recommend you contact Matt Maxwell directly at COMP. 1-800-999-0853
