30404 tpi tuning issues
Discussion in 'FAST Support Forum' started by Iowa, Sep 7, 2019.
  1. Iowa
    Iowa Member
    Jul 1, 2014
    Stock turned port fuel injection30404kit
    Cool CD 306401
    Distributor 305005
    350 tpi 9.5 compression blueprint heads
    Comp 12-464-8 .202 .212 550 546 113 lobe separation made for tpi
    Fuel pump is in the tank from tanks.inc GPA 2 fuel pump
    Fuel pressure is 43psi
    I set my timing on the degree wheel at 30 degrees dropped distributor in. When I go through the set-up wizard it says to set with a timing light to 20 degrees (it reads 50) and when I use the + or - to get the timing adjusted down to 20 motor runs terrible.
    What would be best settings for timing and air fuel as this motor set-up in truck for towing and not racing.
    This should be a torque monster
