5th gen Camaro Street/Stip BBC 540 F2 Procharger
Discussion in 'FAST Support Forum' started by sean english, Apr 28, 2018.
  1. sean english
    sean english New Member
    Sep 6, 2014
    I'm building a BBC 540 F2 Procharger I'm planning on making 1600HP will the XFI 2.0 work for this buid
  2. sean english
    Sep 6, 2014
    I do understand that I have to use different fuel injectors and fuel pump
  3. Fastmanefi
    Sure. The ECU doesn't care what the engine is. Use the correct injectors and the correct map sensor and a good tune and you'll have a great running motor.
  4. sean english
    Sep 6, 2014
    so if got the
    XFI 2.0™ EFI Kit • Big Block Chevy • Up to 1000hp
    SKU: 3011454-10
    I can change some of the components on this system like the FUEL PUMP, FUEL INJECTORS, MAP SENSOR and I want to do a Coil-Per-Cylinder Ignition not the Distributor that come with it is all of this possible
  5. Fastmanefi
    To run CNP you will need to purchase the XIM kit with coils and harness.
