A little help with the new set-up
Discussion in 'FAST Support Forum' started by 69ChevZ28, Mar 8, 2017.
  1. 69ChevZ28
    69ChevZ28 New Member
    Jun 6, 2016
    I am running a 496 stroker making 650 HP with AFR 2101 heads ,Edelbrock 2263 Hydraulic Roller Cam, (makes 11 vac at idle), FAST 3011454 Intake and 30454 Fuel rails, 8 FAST 30752 57 lb injectors with FAST 307603 throttle body married up to FAST EZ EFI 2.0 ECU.
    I have a few questions: .
    1) What MAF/MAP sensor would I need and where should I mount it? (1 bar.....etc)
    2) On the set-up wizard what rate (lbs) should I choose to set-up the injectors? any and all input is appreciated.
    3) for hooking up the throttle cable any suggestions on the bracket I should use? Photos would be a great help
