Can you Log Idle RPM Error for Timing Trim table
Discussion in 'FAST Support Forum' started by karolko, Nov 11, 2018.
  1. karolko
    karolko New Member
    Apr 16, 2012
    As the title says, is it possible to log Idle RPM Error. I would like to do some testing on my timing trim table.
    Speaking of timing trim, does the timing trim table only operate during 0% TPS or is it active during the part throttle cruising for instance?
    Looking forward to getting some answers, and thanks in advance
    Adrian
    Timing trim is only active when the actual TPS% is below the Min TPS% set up in the idle parameters, and no you cannot log Idle RPM error.
  3. karolko
    karolko New Member
    Apr 16, 2012
    thank you fastmanefi. Got the answers i needed.
    Adrian
