chevy 327 dirt track,late body,17 inch of vacuum rule,
Discussion in 'COMP Cams Support Forum' started by fridge, Jan 21, 2016.
  1. fridge
    fridge New Member
    Jan 21, 2016
    what is the best cam for a 327,1968,stock flat top,stock 64 cc heads,
    whit the most torque and H.P over 17 inch of vacuum ?
  2. maxwell
    Jul 5, 2012
    Does it need to be a hydraulic flat tappet? Or can it be solid?
  3. fridge
    fridge New Member
    Jan 21, 2016
    it can be solid
  4. fridge
    fridge New Member
    Jan 21, 2016
    is the L-79 cam good for this application,will it have 17 inch of vacuum
  5. maxwell
    Jul 5, 2012
    The L79 cam should do the job, but we can do better with an Xtreme Energy series camshaft. I would suggest our cam part# 12-268-4, which has a wider lobe separation angle to make good vacuum. It shouldn't have any trouble making 17" as low as 800rpm.
    fridge likes this.
  6. fridge
    fridge New Member
    Jan 21, 2016
    Thanks !!!im going to give it a try !!!
  7. fridge
    fridge New Member
    Jan 21, 2016
    Hi ,
    i have another question,
    will this cam work with 980 valve spring and stock retainer and stock heads,
    i have a 230 lbs open valve spring rule,
    its going to have 1.700 install height
    i thinks it will be fine but just want to make sure!
  8. maxwell
    Jul 5, 2012
    Man, I hate spring pressure rules like that! It honestly leads to more broken parts.
    Trying to use the lightest possible parts is the key.
    I doubt titanium retainers are legal, but is tool steel?
  9. fridge
    fridge New Member
    Jan 21, 2016
    it s got to be original,those tool steel, do they look like original ??
    i have never seen them test somebody spring, what if i use 981
    are those ok?
  10. maxwell
    Jul 5, 2012
    Tool steel are pretty shiny, not black, but a magnet does stick to them.
    I like the 981 spring a lot better.
  11. fridge
    fridge New Member
    Jan 21, 2016
    my cam is ordered,
    can you tell me about a much compression this engine is going to have approx ?
    .040 head gasket compress tickles.
    its a brand new engine with .040 oversize flat top piston.
  12. maxwell
    Jul 5, 2012
    How far is the piston down from the deck at TDC?
    Does the piston have 4 "eyebrow" reliefs? Or just two?
    If the engine is zero decked with a 4 eyebrow flat top piston, you would be at 9.82:1 compression.
    If the piston is down in the bore .010" at TDC, then that makes your compressoin 9.59:1.
  13. fridge
    fridge New Member
    Jan 21, 2016
    its at original deck height, 4 eyebrow
    whats the normal gm piston height ,is it .020 ?
  14. maxwell
    Jul 5, 2012
    I have seen as much as .032. Can't really say until you check it.
  15. fridge
    fridge New Member
    Jan 21, 2016
    ok whit 9.82:1 is 94 octane gas going to be ok
    and at what would you set your engine timing at wot or total timing ?
    thanks in advanced Matt
    really helpful !!!
  16. maxwell
    Jul 5, 2012
    I think that is plenty of octane for that compression. I would start out at 32 degrees total to shake the car down, then bump it up a little at a time and see where it runs the best.
    My guess is 34-35 will make the most power.
  17. fridge
    fridge New Member
    Jan 21, 2016
    hi Max,
    can i use 981-16 or 980-16 valve spring with my stock gm retainer ?
    thanks again
  18. maxwell
    Jul 5, 2012
    They should fit the factory retainer fine. Since it is a race application, it would be worth investment to get a good set of retainers and valve locks. Unless it is against the rules...
  19. fridge
    fridge New Member
    Jan 21, 2016
    Hi Max,
    the engine is at the machine shop,
    what kind of h.p and torque should i have with this set-up approx ??
  20. maxwell
    Jul 5, 2012
    Well, that's the $64,000 question! A dyno is the only way to know for sure.
    I would expect the Xtreme cam to be worth about 10-20hp over the L79 cam.
