COMP Cams Quick Tech Video: Achieving Proper Rocker Arm Geometry
Discussion in 'COMP Cams Technical Reference Articles' started by jjamros, May 25, 2011.
  1. jjamros
    jjamros Guest
    Memphis, TN − The latest Quick Tech Video from COMP Cams helps engine builders maximize their engines’ potential by achieving proper rocker arm geometry.
    The COMP Cams Quick Tech Video series helps racers, engine builders and automotive enthusiasts at all levels discover secrets to maximizing power potential. Proper rocker arm geometry is crucial to achieving maximum valve lift, stability, durability and performance. In this latest video installment, Achieving Proper Rocker Arm Geometry, COMP Cams R&D engineers walk viewers through the process of determining the correct pushrod length to make sure the rocker arm is properly aligned with the valve tip. The Achieving Proper Rocker Arm Geometry and all other COMP Cams Quick Tech videos can be found in two locations - www.cpgnationtv.com and on the COMP Cams YouTube Channel at www.youtube.com/compcams.
    Quick Facts
    Product: COMP Cams Quick Tech Video: Achieving Proper Rocker Arm Geometry
    Direct Link:
    Social Media Pitch: The latest Quick Tech Video from COMP Cams helps engine builders maximize engine potential by achieving proper rocker arm geometry​
