COMP Cams Quick Tech Video: How To Install An LS Rocker Arm Trunion Upgrade Kit
Discussion in 'COMP Cams Technical Reference Articles' started by dhodgdon, May 18, 2012.
  1. dhodgdon
    dhodgdon Administrator Staff Member
    May 9, 2011
    Memphis, TN − The latest Quick Tech Video from COMP Cams guides LS performance enthusiasts through the various steps to install an LS Rocker Arm Trunion Upgrade Kit.
    Upgrading the stock rocker arms is critical for any high performance application that experiences higher than stock RPM levels. In this COMP Cams Quick Tech Video, viewers are walked through the instructions to install the LS Rocker Arm Trunion Upgrade Kit. This kit converts a stock LS1, -2, -3, -6, -7 or L92 rocker arm to a captured bearing trunion rocker arm. This upgrade will increase overall performance and durability. Viewers will learn about all the included components, and will see both how the rockers are pressed to remove OE trunions, and how the COMP trunions are installed before final installation on the engine. Retailing for around $135, this is one upgrade that you truly can’t afford to pass up. This latest video and all other COMP Cams Quick Tech and How-To videos can be found at www.cpgnationtv.com.
    Quick Facts
    Product: COMP Cams Quick Tech Video: How To Install An LS Rocker Arm Trunion Upgrade Kit
    Part #: 13702-KIT
    Social Media Pitch: This COMP Quick Tech Video provides a walkthrough for installing an LS Rocker Arm Trunion Upgrade Kit for better performance & durability
