COMP Cams Quick Tech Video: Selecting The Correct Fuel Pump Pushrod
Discussion in 'COMP Cams Technical Reference Articles' started by dhodgdon, May 18, 2012.
  1. dhodgdon
    dhodgdon Administrator Staff Member
    May 9, 2011
    Memphis, TN − The latest Quick Tech Video from COMP Cams provides viewers with the knowledge needed to select the correct fuel pump pushrod when buying a new cam or high pressure fuel pump.
    When you are upgrading your camshaft in a vehicle equipped with a mechanical fuel pump, you may also need to upgrade your fuel pump pushrod to ensure compatibility with your new cam. This is an important but often overlooked process. Simply, the material that the pushrod is made from must be softer than the camshaft material. This will keep your engine running both safely and at peak performance. The video provides viewers with an overview of the correct pushrod materials to select for each type of cam, and offers a variety of special notes to ensure that all of your valve train components work optimally. This latest video and all other COMP Cams Quick Tech videos can be found at www.cpgnationtv.com.
    Quick Facts
    Product: COMP Cams Quick Tech Video: Selecting The Correct Fuel Pump Pushrod
    Social Media Pitch: The latest COMP Quick Tech Video shows viewers how to select a correct fuel pump pushrod when buying a new cam or high pressure fuel pump
