Computer connections removal
Discussion in 'FAST Support Forum' started by Russ67scode, Dec 16, 2017.
  1. Russ67scode
    Russ67scode New Member
    Oct 6, 2016
    So I want to hook up a shift light and it goes to the 25 grey pin connector #1 I thought I could use one of the 40 connections I did use but I can’t seem to remove the wire from the connector. I know you need to push out the small white lock
    If I can’t remove one what type of connector do I need ?
    Thanks Russ
  2. glasman64
    glasman64 New Member
    Oct 24, 2016
    Here is a video showing you how to unpin the connector.
    Russ67scode likes this.
  3. Russ67scode
    Oct 6, 2016
    Thank you very much. glasman64
