e-dash comm error
Discussion in 'FAST Support Forum' started by lilpiston8, Mar 1, 2018.
  1. lilpiston8
    lilpiston8 New Member
    Aug 29, 2010
    have xfi 2.0 and a e-dash. Turned car on today and the e-dash flashes between home screen and a screen that says (comm error, recheck connections and power to fast ecu). checked them all, all seems good. Ideas?
  2. lilpiston8
    Aug 29, 2010
    also laptop cannot connect to ecu as well. just says ecu not found
  3. Fastmanefi
    What version of laptop software do you have?
    No comm errors using the laptop?
    What connector do you have the laptop plugged into?
  4. lilpiston8
    Aug 29, 2010
    software version is 2.051. laptop cannot connect as well, just says ecu not found. using com 6 with a serial/usb connector that works perfectly with my ignition box always had with the fast system. do not know if car will run as just installed a crank trigger and it is not set up yet. tried to connect to fast box to set it up and nothing. just says ecu not found. checked all fuses and wiring. all is good.
  5. Fastmanefi
    You will have to match the comm ports (Windows to ECU). Choose Comm 4 in the sportsman (Communications/Setup/Com Port). Then go to the Windows Device manager and make sure the USB is assigned to Com 4. Once they match you should be able to connect.
  6. lilpiston8
    Aug 29, 2010
    thats not the problem, been through all that. changed it to com 1, matched everything and still nothing. i know its not the cable because i can talk to my ignition box (its set up the same way)
  7. lilpiston8
    Aug 29, 2010
    I also cannot ping the ecu, if that matters. thanx.
    Have you tried re-installing the C-Com software? Sounds like something could be blocking it.
  9. lilpiston8
    Aug 29, 2010
    have not tried that yet, but why would the e-dash not connect to the ecu as well?
    It's possible an ECU firmware setting is off that you can correct once the C-Com software connects. Setup with the C-Com software is a requirement. The eDASH cannot make all the initial needed settings.
