Error Code 32 Voltage Fault
Discussion in 'FAST Support Forum' started by Dart67, Apr 11, 2018.
  1. Dart67
    Dart67 Member
    Sep 12, 2011
    Jessieville, Arkansas
    XFI 2.0 2.051
    I am all of a sudden getting an Error Code 32 Voltage Fault.
    I thought at first that my Optima Yellow top had died.
    I switched to a known good fully charged battery and still get the code.
    When I look at the battery voltage on the Dashboard, it starts out at about 13 volts then rapidly climbs up to 22 to 23 volts.
    If I measure the voltage on connector B18 it is right around 12 volts.
    I have been waiting again all afternoon for an auto call back from FAST Tech Support and as usual no call back.
    Any Ideas ?
    Herb
  2. Denis
    Are your fast ECU red and black power leads connected directly to the battery? Measure the voltage between battery ground and the pink wire going to the ECU from the ignition switch. When the ECU measures system voltage it is sensing the voltage on the pink wire.
    You could have a grounding issue. You might measure voltage between alternator case and battery ground. It should be close to 0 volts.
  3. Dart67
    Dart67 Member
    Sep 12, 2011
    Not a wiring problem. ALL power and grounds ran direct to battery on 10 gauge wire. Engine not started or running. Same results with alternator connected or disconnected.
    I finally got to talk to a tech this morning and the ECU is now on the way to Memphis.
    Herb
