EZ EFI 2.0 Throttle Body System Vehicle #2 - An '81 GMC
Discussion in 'FAST Support Forum' started by A A, Jun 5, 2016.
    Be sure to "blip" that rear throttle several times with the main throttle closed. This will let you know if the rear throttle is sticking open.
    Maybe this will allow the ECU build better fuel maps.
    Decided to start working for better fuel mileage from the GMC today. With the regular gas I use, 28 total mechanical degrees is all this engine will stand using a 4000 RPM slope - before pre-ignition starts. The default 60% vacuum load setting also never allowed any added vacuum timing on this engine. I bumped my vacuum timing from 6 to 10 degrees - keeping the 45% load figure I was already using. I felt the engine smooth out a bit more between 1400 and 1600 RPM, and checked the plugs. The plugs looked good, but were beginning to soot some on the ceramic insulators. I pulled idle A/F from 14.3 to 14.5, and reset cruise A/F from 14.7 to 14.8. The plugs began burning cleaner again, and the engine was responding well and sounding ever so slightly mellower at the exhaust through the RPMs. I then took the initial to 20 degrees and went for a drive. There was no problem with mild or hard acceleration (no pinging), and a later check of the plugs showed no oil deposits or other problems. I'm sure hydrocarbons are down while nitrides have risen. There is no doubt in my mind that mileage just jumped up from the 12 MPG I had been getting. I'll be keeping these new settings to see how much my mileage improves - so long as the engine continues to run sweet at them.
    Edit:
    Decided 48 degrees total timing was too aggressive a jump and pulled the vacuum advance back 4 degrees to 16 degrees for a total of 44.
    After putting the GMC through some aggressive paces, I found a small spot of oil on two sparkplugs, and the side electrode heat line appeared closer to the plug base. The slight oiling was nothing that wouldn't burn off quickly in normal driving. I dropped the vacuum load percentage to 40% and put the GMC back through the same aggressive tests as before. The spot of oil is no longer appearing to the inside ceramic of the two plugs, and the heat line appears normal again in the affected sparkplugs.
    Decided to check the headers for any leaks today - and found a few very slight ones. Some bolts were a little loose, but not bad for the first time since the headers were installed.
    While the engine was still cold, I turned the air conditioning on and dropped the transmission in gear. Noticed the engine used all of the default 5 degrees of idle trim - increased this to 8 degrees and saw that was the sweet spot as the engine warmed. Once the engine warmed, I increased the initial timing from 20 to 24 degrees, and saw the engine liked this also in drive with the air on. IAC became more stable and low engine RPMs became smoother. The engine is sounding even sweeter out the exhaust as I move the RPMs up and down.
    I should start seeing even more fuel use improvement. I was expecting I could improve this along, and the EZ EFI 2.0 ECU
    appears to be processing the information it sees more efficiently. Not bad for an engine that has more compression than I remembered building it with - and the performance cam I matched to it in 1990.
    Here are the previous settings:
    Initial timing 20 degrees
    Idle trim 5 degrees
    Idle A/F 14.4
    Cruise A/F 14.8
    WOT A/F 12.7
    Slope All-In 4000 RPM
    Mechanical All-In 28 degrees
    Vacuum Timing 7 degrees @ 45%
    Total Timing 35 degrees on Standard Oil Regular (Chevron 87 Octane with Ethanol and Techron)
    .. and here are the current settings:
    Initial timing 24 degrees
    Idle trim 8 degrees
    Idle A/F 14.5
    Cruise A/F 14.8
    WOT A/F 12.7
    Vacuum Timing 16 degrees @ 40%
    Total Timing 44 degrees on Standard Oil Regular (Chevron 87 Octane with Ethanol and Techron)
    After noting the idle trim compensation operation with the air conditioning on, transmission in drive, I have now turned on the full 12 degrees of idle trim.
    While 12 degrees of idle trim appeared to help idle with the air conditioning on in drive, It seemed to be creating other issues at RPMs just under the idle trim cutoff. I have now turned off the idle trim. Throttle increases from 750 idle RPM up are now smoother. The trade-off was IAC is now pegging in drive with the air conditioning on at idle, and quick throttle return from higher RPMs to idle dips to 400 for a moment If I add any idle trim back, it will probably be only enough to aid in holding RPMs from dropping too far below 750 with a quickly closed throttle. I then dropped the initial to 22 degrees.
    I'm also getting very slight cold and warm idle improvement using a 14.6 idle F/A target. Engine is sounding very sweet now in 750-1050 RPM throttle application.
    Found 1&2 cylinder sparkplug ceramic glazed and fouling. Replaced the factory heat range UR-4 plugs with colder UR-6. Engine idle smoothed back out. Cold start still fine with UR-6 plugs and current F/A ratios.
    Well, this has been strange. No errors, no IRM #s, no header leaks. But, I had to drop idle back to 14.5 A/F, cruise to 14.7 A/F, initial timing to 20, and had to pull the vacuum timing back to 12 degrees. I also pulled the total mechanical timing back to 26 degrees. The plugs are looking correct again. I'll have to drive it a while before trying to get the mileage higher again. The one variable that changed, before losing ground, was I had changed over to a tank I had filled two months back. I'm betting I mistakenly pumped mid-grade fuel in the tank I had been using in my earlier tuning - and didn't realize it. Engine is running sweet again. At least I have some timing numbers for mid-grade fuel now. For now, I'll keep running the UR-6 plugs.
  10. Pfingstl
    We have 95 Octane as the standard gasoline (+ $6 / Gallon) and Shell sells 99 Octane - of course even more expensive!!
    Only unleaded.
    And bad fuel isn't nice. Just service some old classic cars with 5-8 year old fuel. No power and the smell.......................................
    A A likes this.
    Hi Jens,
    We/re lucky here - 87 Octane @ $2.18 a gallon. 89 Octane @ $2.48. 92 Octane @ $2.88. Now in Venezuela, it was pennies a gallon for decades - it just went up 60 times to about $2.00 a gallon. Still not worth a trip there. ;)
    Last time I checked, 5 gallons of 100 octane fuel here was about $70. :(
    Yep! I well know that old fuel smell - I bought some classics that had fuel 10 years old and more. It's bad to varnish up fuel systems also. It's best to drain and use that old stuff carefully for outside fire starting - and use a good fuel system cleaner to flush out the varnish. Old oil can be about as bad too. If it isn't contaminated too bad, I filter and mix it in with my diesel fuel and burn it. If it's really bad, I mix it with the old bad fuel - and use it outside to burn debris. It still has an odor that doesn't soon go away.:eek:
    The reason I switched tanks while tuning.... The tank started showing empty at the gauge. Turned out to be the in-tank fuel pickup assembly - as the tank was still almost three quarters full. Probably good it happened now and not later. I also finally remembered why I had put higher octane fuel in that tank - I had heard some clicking injectors at startup I wanted to clean. The higher octane worked and stopped the clicking from the injectors. I had filled the TA with the same higher octane fuel on that same day. My old memory is throwing curves at me. Hopefully, I won't forget what fuel I have in the TA.
    With the weather now in the teens frequently, I decided it was time to re-visit the fuel settings on the GMC. With no intake heat on the tall single plane intake, I knew there would be no quick intake warmup for best fuel atomization. However, the engine still started perfectly in the cold, and warmed up very nicely in warm weather. One problem, in the low temperatures the cold engine would die and stumble after giving it some throttle and then quickly letting off the throttle in neutral - if you didn't allow it to warm up at idle first in these cold temperatures. I've pulled the idle A/F back to 14.0, and reduced the cold enrichment fuel six points - since richer idle A/F mixtures than around 14.4 - 14.6 have always left signs of gas fouling at the plugs at cold start in warm weather. I also reduced cranking fuel four points, but warm starts are still perfect in cold or warm temperatures.
    Problem two was I still was getting a spot of oil on the inner ceramic of some plugs at times after WOT. I determined this had nothing to do with my 14.7 cruise A/F or the lean idle A/F, and was not due to my timing. It also had nothing to do with the cylinders or heads. I adjusted WOT one tenth richer to 12.6 - and that problem seems to have disappeared.
    Accelr fuel has never needed any adjustment and still hasn't. So, I've left it alone.
    I'll have to see how the engine reacts to these changes over the next few days in cold starts. As far as driving, the truck still runs perfect.
    Man, this is sickening. My right hand fuel tank is full of fuel, but the engine began running worse and worse. I switch to the left hand tank and everything begins running normally again after a minute. The truck is running like it has a tank full of water every time I switch over to right hand tank. If I catch the culprit, they won't make it back off my property again. Now I have to review security camera footage.
    Update:
    Well, nothing so nefarious as watered down gas by some prankster. The fuel filters were a little dirty, so I changed them. Then the truck wouldn't start at all - no ignition spark. If something hasn't happened in the distributor or coil, something has failed with my MSD 6T. If the 6T has failed, it looks like it's time for a new FAST ignition box. Murphy's law really knows when to give me a kick. What is really strange, was how the engine acted up every time I switched on the right fuel tank and how everything cleared up a minute after I would switch back to the left tank. Gremlins, evil fairies, Joe Btfspik, some curse?
    Anyone know if the FAST E6 is compatible with the MSD canister style Blaster 3 coil? Or, will I need to use the E92 coil?
    The FAST E6 with E92 coil kit is on its way. Summit rep says the Blaster 3 coil should be fine with the E6. I'm going to try for a more definitive answer from FAST tech.
    FAST tech says the MSD 3 coil is fine for use with the E6. So, I can keep the MSD 3 coil in place on the intake and change nothing but the box..
    Should have had my new FAST E6 today, but UPS was scared to come out - no snow, no ice, just cold weather. Too cold for me to install it anyway - but not having the truck running in this cold weather is keeping me from optimizing the new idle A/F and cold start settings.:(
    I didn't check my antique 6T out much beforehand because it really needs to go back on the car I took it off of - with its other MSD box connectors - Engine Builder's Delight, timing computer, and other timing controls. Once I had it off, it checked out good. The stinking fairly new MSD Blaster 3 coil was bad - after only several hundred miles of use, yet out of warranty date of course. So, I will be building a bracket for the FAST E92 coil and using it. I did get the new FAST E6 mounted and wired - and the engine started but began acting the same as before, in seconds, using the MSD coil. The FAST E6 box is slightly longer and much heavier than the MSD 6T and 6AL boxes - if that means anything..
    The good thing - I don't need to send the MSD 6T in for repair. I'm also glad the MSD coil failed in the driveway and not on the road. :D Hopefully, it will be warm enough Friday for me to mount the new E92 coil, and start checking my new idle F/A settings again.
    Back to the drawing board. I didn't like the way the larger E6 looked where the smaller MSD 6T had been. I've decided to mount the new coil in that space for a less crowded look. My loaded '81 GMC doesn't offer many neat placement choices for the E6, So, I'll be lengthening wires and installing it inside the cab. I actually have a stereo amplifier system oversized battery supply behind the passenger side front seat I can tie into for the E6 main power. There is plenty of room for the E6 behind the driver side. The other E6 wires will run neatly under the carpet and through the firewall - making the wiring even cleaner and neater under the hood. This also means I'll be able to more easily see the E6 diagnostic LED if and when needed - and the E6 will also be well insulated from any electrical noise. I have a MSD noise capacitor I'm also going to use with the E6 main power wires.
    waybad1 likes this.
