EZ/Sportsman and XFI Replacement O2 Sensor Numbers
Discussion in 'FAST Support Forum' started by fabr, Feb 3, 2019.
  1. fabr
    Thought this would be easier found for those needing the info than in the topic I posted it in. Anyway,here ya go.
    Bosch numbers 17205 and 17018 both will work with EZ or Sportsman. 17205 has the original 15" overall length for approx $125. 17018 has longer 17" overall length for approx $70. Yes,the only difference is the lead lengths and yes,the longer one is cheaper. Both operate identical to the "FAST" sensor that is just a 17205 Bosch off the shelf sensor. Plug and play. FAST has their replacement for approx $98 + shipping. Local parts store should save you almost $30 and free shipping to boot.
    LSU 4.2
    5 Wire Wideband Oxygen Sensor
    Bosch OE # 0 258 007 206 ( 0258007206 )
    AEM # 30-2001
    Autometer # 2243
    FAST # 170408
    Dynojet Wideband Commander # 48292001
    GM # 12575657
    AC/Delco # 213-1572
    PLX Devices # Type B
    Motec # 57005
    Bigstuff3 BS3 JMI-003-001
    *Note* This is the same sensor as the Bosch 17018 - The 17205 has a wire harness length of 15"
    __________________________________________________________
    XFI shows a different O2 sensor. It is an NTK NGK 24302. They can be had for $100 almost anywhere also. Same exact one as the FAST for $260!!
    NTK Sensor for use with NGK Powerdex AFX
    NTK Sensor for use with FAST XFI ECU
    Fast # 301422
    NTK # LHA LZA-08-H6
    Honda # 36531-RCA-A01
    36531-RCA-A02
    36531-RDJ-A01
    36531-RDM-A01
    Saturn # 12581687
    12581688
    Bosch # 13965
    15401
    15906
