FAST Dash voltage reading off.
Discussion in 'FAST Support Forum' started by CMD, Apr 23, 2018.
  1. CMD
    CMD Member
    Sep 3, 2011
    My FAST dash voltage reading is 2 volts lower than my laptop and Autometer voltage gauge after new XFI black box install with 2.05, replacing XFI 1.34 without ITC, which was working fine. I'm sure I probably missed something in the set up. Any thoughts would be appreciated.
    Thanks , CMD
  2. Denis
    The FAST ECU measures voltage on the yellow wire going to the ECU from the ignition switch. Measure the voltage on that wire and see what you have. My XFI never agrees with my Fluke meter, always a little low.
  3. CMD
    CMD Member
    Sep 3, 2011
    Thanks......I'll check that. So there are no adjustments to make as I had to do with the pressure sensors?
  4. Denis
    No adjustments to make. The calibration on the voltmeter is fixed.
  5. silvernblack
    silvernblack Member
    Dec 18, 2011
    Mine reads about 1.7 vdc low all the time. I took a voltage reading at the IGN connector and, YES, it reads about 1.7 vdc higher there than on the handheld indicator.
    The FAST EZ EFI 2.0 handheld should read the same voltage found on the ECU pink ignition sense wire. This is the wire the ECU/handheld gets its reading from. A lower reading on the handheld, than found on the ECU pink ignition wire, can indicate an ECU problem that will get progressively worse.
  7. silvernblack
    silvernblack Member
    Dec 18, 2011
    Hmm... My EZ-EFI 2.0 has read the same low reading since I installed it about 4.5 years ago. I will check my wiring to make sure it's nice and tight.
    Temporarily connect the pink ECU ignition wire directly to the positive battery terminal. The handheld should then read the same voltage as read at the battery terminals. Many people just add a relay to supply direct battery power to the pink ECU ignition wire.
  9. silvernblack
    silvernblack Member
    Dec 18, 2011
    I gather the PINK lead labeled "12v Switched" that goes to Terminal "32" on the ECU Drawing? I'm working under dash now so that's why I am folllowing up.
    The pink wire is the ignition +12 switched wire. It controls turning the ECU on and off and supplies the voltage reading for the ECU screen.
  11. silvernblack
    silvernblack Member
    Dec 18, 2011
    Well... I added a relay powered from the IGN terminal in the fuseblock (where pink 12 was coming from before) and the power source for "switched pink" comes off the Terminal on the horn-relay(battery/alternator junction on 60s-70s GMs) in the engine compartment.
    Well, I'll be dipped!!! The voltage reading on the handheld now reads the same as what the multimeter reads on my battery when the car is running. I'm happy. :)
    There you go, and all it took was Scotty getting the warp engine performance percentage points up a wee bit. ;)
