FAST Dual Sync #305005 Install
Discussion in 'FAST Support Forum' started by thefunge, Sep 4, 2017.
  1. thefunge
    thefunge New Member
    Dec 26, 2013
    Using the "alternate installation method" for unpowered distributors found on page 27 of the EZ-EFIĀ® 2.0 installation instructions, Step 3 says to "Set the distributor to the #1 position and drop it into the engine" after rolling the engine to 30 degrees BTDC. What exactly does "Set the distributor to the #1 position" mean? Does it mean to install the distributor as you would a conventional distributor by lining up the rotor tip with the #1 cylinder?
    Also, on page 2 of the Dual Sync #305005 install instructions, there is a note about the distributor cap which reads "the #1 plug wire terminal is marked with a band. Be sure to connect the #1 plug wire to this terminal".
    With these instructions in mind, I rolled the engine to 30 degree BTDC, and then set the distributor into the engine by lining up the rotor tip in the general direction of the #1 cylinder. Then I followed the remaining steps under the alternate installation method. In the end, the distributor cap is oriented as shown on this photo with the banded #1 terminal and rotor pointed toward the #1 cylinder. Can someone confirm if this is the correct approach and the correct orientation of the cap when all is said and done?
    Thanks,
    Frank
    Sounds like, looks like - you got it right.
  3. thefunge
    thefunge New Member
    Dec 26, 2013
    Thanks for confirming!
