FAST dual sync new install
Discussion in 'FAST Support Forum' started by HKMustang99, May 16, 2017.
  1. Pfingstl
    I haven't grounded any excessive wires. Did all as per instructions.
  2. Fastnofast
    Fastnofast Member
    May 16, 2017
    You were lucky sure.
  3. Pfingstl
    Just a stupid question.
    Do you have the tach signal between ecu and dual sync connected ?
    And the same degrees set in the wizard as the dual sync - with the most vacuum - so that the ecu knows the actual degrees.
    Example 20 degrees.
  4. Fastnofast
    Fastnofast Member
    May 16, 2017
    The dual sync is connected with the FAST harness only. The degrees set in the wizzard is 20 and i had a chance to set the dizzy at 20 with the ecu and fixed timing when engine ran. I didn't change setting in vaccum parameters
  5. Fastnofast
    Fastnofast Member
    May 16, 2017
    Well. Today after doing lot of modifications on ground, harness , no start
    I disassembled the dizzy and i saw something wrong. The rotor tip is too near the cap and had damaged the cap. Rotor tip is not aligned to the center of the electric studs so i need to bend the rotor tip. After done that engine would crank better but never ran. Also, i saw that at low rpm while i crank the point led on the ez efi don't blink correctly. Some points missing and my timing light confirm that. I finally decided to remove fast dizzy and install old hei with rpm module and engine ran successfully. Do you know a good brand dizzy with same features than the fast dizzy to connect to the ezefi?
  6. Pfingstl
    Glad to hear you found the problem. Perhaps the cap was installed wrong by accident. It happens.
    I don't know of any alternative, but why not just get a new rotor (and cap).
  7. Fastnofast
    Fastnofast Member
    May 16, 2017
    I don't want to use this Fast dizzy any more because of the bad signal coming from inside the crank trigger i suppose. I'm gonna try to find an other dizzy with crank trigger but do you know if FAST dizzy use Hall Effect crank trigger style ?
  8. Denis
    The FAST Dual-Sync distributor is a hall effect device. The 12V going to it is for power to the hall effect devices used for cam and crank sync.
  9. Fastnofast
    Fastnofast Member
    May 16, 2017
    Ok thank you denis. Next time i will check with a msd dizzy and inductive crank trigger. And i will use crank trigger input in the fast efi.
  10. Fastnofast
    Fastnofast Member
    May 16, 2017
    Ok. Here are some news. I received a msd distributor with magnetic trigger. engine started but i need to open the throttle blade to help start. may be too much fuel in crank parameters setting. After start i lock timing to 20 degrees and with my timing light i see fluctuations on the damper. Light is not steady on 20 degrees. I think rotor phasing is not good so i ordered a new distributor cap to use as a spare. I will drill a hole to check phasing.
