fuel pressure switch
Discussion in 'FAST Support Forum' started by jaros44sr, Dec 1, 2018.
  1. jaros44sr
    jaros44sr Member
    Nov 12, 2012
    phila., pa.
    any help for pressure switch in fuel tank, directions from FAST leave a lot to be desired, one paragraph. Wiring schematic?
    Fuel pump is from a 2000 Chevy pu
  2. Caprimaniac
    Caprimaniac Member
    Nov 6, 2011
    What is the switch supposed to do? Fuelpump on and off?
    How is the switch going to get it's input? By a pressure sensor?
    A pressure sensor normally goes into the fuel lines; couple of different setups possible.
  3. jaros44sr
    jaros44sr Member
    Nov 12, 2012
    phila., pa.
    Good questions, that I don't have a clue to the answers, just don't know if I need a pressure switch in case of over pressure in the tank
    here is the fuel pump I'm using
    [​IMG]20181203_083757
  4. jaros44sr
    jaros44sr Member
    Nov 12, 2012
    phila., pa.
    You can just see it above the cylindrical aluminum part
    [​IMG]20181203_084741
  5. Caprimaniac
    Caprimaniac Member
    Nov 6, 2011
    If there is a chance of pressure in tank getting to high(???) and this is an OEM type sensor, I suggest you figure out what the switch do in the OEM Application and translate that into Your XFI- veichle. If you also figure out what kind of signal the switch gives (ON/OFF or else?), you can use the signal on one of the inpust on the XFI to shut Down the system or even on a relay shutting Down the pump or the engine, or whatever.
    If not; leave the sensor alone and drive...
  6. fabr
    Is it possible that switch is actually the roll over shut down switch. If it gets fuel on it the pressure increases on the switch above atmospheric and shuts down the pump? Just a guess.
  7. jaros44sr
    jaros44sr Member
    Nov 12, 2012
    phila., pa.
  8. fabr
    AA gets the prize. The fuel tank pressure sensor is part of the fuel pump assembly and is mounted on top of the tank or inside the tank. It's part of the evaporative emissions system (commonly referred to as “EVAP”) and reads pressure in the fuel system to detect evaporative leaks, such as a loose or faulty gas cap.
  9. jaros44sr
    jaros44sr Member
    Nov 12, 2012
    phila., pa.
    Thanks guys for the help, now I'll just search wiring diagrams to hook it up
