Idle speed not sticking
Discussion in 'FAST Support Forum' started by sschroeder, Apr 13, 2017.
  1. sschroeder
    sschroeder New Member
    Aug 3, 2011
    Oklalhoma
    I'm trying to tune a new XFI Sportman system and have run into a problem where the idle speed vs. coolant temperature keeps changing on it's own. I'll go into the table and adjust it so the idle is about 800 rpm when warmed up. But after every couple of start/stop cycles it resets itself to about 1,000 rpm. I don't get it. I can set it, shut down the motor, start it back up again several times in it's fine. Then the next time it'll be back up to 1,000 rpm.
    What am I doing wrong? I have noticed that when I try to write the tables back to the ECU, even though it tells me I'm about to overwrite what's in the ECU, when it's done, it will say 0 of 1792 bytes in the dialog box.
    Steve
    Fastmanefi Member
    If it says 0 bytes changed, then it didn't change anything. The program you are reading is the same as what's in the ECU.
  3. sschroeder
    Aug 3, 2011
    Oklalhoma
    That's what I thought. Which is kind of secondary to why the CTS vs Idle speed is changing on its own.
