When I overlay a log onto any of the tables I have a white line trace of the football of the entire log. It is like someone scribbled all over the table to the point it is unreadable. Any way to correct this? As it is it is impossible to use.
The point is to show you where the engine was at each data log point. As you move around in the log the football shows you the vacuum and RPM that was in effect at that time.
That doesn't work. Yes,that allows zooming in on the log but it does not overlay on the table just the area zoomed in on. It still shows the entire logs football trace on the table making the table unreadable.
That has no bearing on the question I asked. I asked if the white line traces of the path the football takes around a table when overlayed with a log can be removed so that with long logs the table values can be read instead of being unreadable as my pic shows. Apparently not. What I was wanting to do was log multiple 3rd gear pulls at differing rpms/throttle positions with one log session but since the white line traces obliterate the table that isn't really possible.
I understand what you said. You guys don't understand what I'm saying. Fast SHOULD have incorporated a feature that would allow a person to make a longer log,take a snippet of that log ,save it and overlay just that snippet over the table instead of the entire log. Thanks everyone for the replies and I do appreciate it.
