minimum distance to mount EFI ECU from E6 Ignition
Discussion in 'FAST Support Forum' started by crash520, Jul 15, 2017.
  1. crash520
    crash520 New Member
    Guys, I have a good spot to mount both my XFI Sportsman ECU and E6 Ignition box inside the cab under the dash, I know its not great to have both units close to one another nor run cabling close to one another, what would be considered the min distance to mount the EFI ECU from the E6 module please, I intend on running the cables out through the firewall, the only cables for the ignition will be the two wires to the coil, all others will be EFI cabling, I can separate the coil wires from the rest by around 6-8", this should be enough right??, as for the ECU and E6 ignition, Im looking at making a panel that should give me a good 6"-8" of separation between the boxes, between the boxes I'd mount the EFI harness relays and fuses etc.
    any thoughts or suggestions please?? anyone have any photo's of what they have done that might be able to assist me please??
    the install is on a 73 Cuda with the heater box removed
