Need Help GM Big Block with XFI 2.0 and XIM
Discussion in 'FAST Support Forum' started by VictorGarage, Apr 9, 2017.
  1. VictorGarage
    VictorGarage New Member
    Apr 9, 2017
    hello im planning to install the XFI 2.0 and XIM on the GM Big Block engine
    i am going to install it 1 by 1
    because i had it running missfired last time i installed altogether
    if you guys had any simple guidance step by step on installing this to my Big Block i am very glad to have it here...
    i am planning to install my XFI first...
    and will update you guys on progress..
    need a GURU here...
    please help
    Fastmanefi Member
    I sent you an email.
  3. VictorGarage
    Apr 9, 2017
    thanks... please send to victorgaragesmg@gmail.com
    i need detail on how place the cam sensor... my crank is 50 btdc with 4 mag wheel
    and sync them together...
    Fastmanefi Member
    Sent email
  5. VictorGarage
    Apr 9, 2017
    i dont see any email come in from you
    can you give me your email >
  6. VictorGarage
    Apr 9, 2017
    can you guys help me installing XFI2.0 and XIM with Fast Dual Sync Distributor? i make it run with standalone XIM... but no luck on CAN enabled... the timing stay at zero...
    please send me email or reply my threads
  7. Fastmanefi
    Fastmanefi Member
    The dual sync connects to the discrete crank and cam inputs on the XIM. The IPU inputs need to be looped to digital ground. Then the XIM plugs into the cam/hall effect plug, and the CAN bus connectors need to be connected. Don't you have the instructions? If not they are attached to this post.
    Internal DIP switches must be set correctly too.
    00001101 for a dual sync dizzy set at 50* BTDC, 8 cylinder, CAN enabled, coil per cylinder.
