No staus light FAST XIM
Discussion in 'FAST Support Forum' started by csjta, Mar 11, 2018.
  1. csjta
    csjta Member
    May 26, 2011
    Need some help guys
    Setup is LS1 with XIM. Car has been down for 2 years getting engine upgrades. Car will start and run, but no Status Light on XIM, so timing is fixed.
    Checked Can Connections and everything is hooked up and terminated (unused Can connection)
    What would cause the No Communication between the ECU/XIM? Can is enabled in the ECU, I have verified CAN wire integrity with ohm meter from XIM to ECU.
    Did you enable the CAN in the XFI under Can Configuration?
  3. csjta
    csjta Member
    May 26, 2011
    Yes, can stream is enabled
