O2 connector XFI
Discussion in 'FAST Support Forum' started by RonnieW, Feb 1, 2019.
  1. RonnieW
    RonnieW Member
    Oct 21, 2009
    Jacksonville, Fl
    My WB connector got on the header and melted. Can you get replacement connectors, both male and female side. I hate to pay the $260 FAST price for a new sensor when I have a good one that I can't use.
    Just replace both ends with a Weatherpak.
  3. fabr
    You can buy the wideband if ever needed from most any parts store for $70. I'll get the part number and post it up. I just replaced mine last week.
    Russ67scode likes this.
  4. fabr
    Bosch numbers 17205 and 17018 both will work with EZ or Sportsman. 17205 has the original 15" overall length for approx $125. 17018 has longer 17" overall length for approx $70. Yes,the only difference is the lead lengths and yes,the longer one is cheaper. Both operate identical to the "FAST" sensor that is just a 17205 Bosch off the shelf sensor. Plug and play. FAST has their replacement for approx $98 + shipping. Local parts store should save you almost $30 and free shipping to boot.
    LSU 4.2
    5 Wire Wideband Oxygen Sensor
    Bosch OE # 0 258 007 206 ( 0258007206 )
    AEM # 30-2001
    Autometer # 2243
    FAST # 170408
    Dynojet Wideband Commander # 48292001
    GM # 12575657
    AC/Delco # 213-1572
    PLX Devices # Type B
    Motec # 57005
    Bigstuff3 BS3 JMI-003-001
    *Note* This is the same sensor as the Bosch 17018 - The 17205 has a wire harness length of 15"
    __________________________________________________________
    XFI shows a different O2 sensor. It is an NTK NGK 24302. They can be had for $100 almost anywhere also. Same exact one as the FAST for $260!!
    NTK Sensor for use with NGK Powerdex AFX
    NTK Sensor for use with FAST XFI ECU
    Fast # 301422
    NTK # LHA LZA-08-H6
    Honda # 36531-RCA-A01
    36531-RCA-A02
    36531-RDJ-A01
    36531-RDM-A01
    Saturn # 12581687
    12581688
    Bosch # 13965
    15401
    15906
  5. Russ67scode
    Russ67scode New Member
    Oct 6, 2016
    Are the connections the same as the fast ?
    Thanks for posting this
  6. fabr
    They are the exact ones supplied by FAST. FAST just repackages them. Yes the ends are exactly the same because of that.
  7. RonnieW
    RonnieW Member
    Oct 21, 2009
    Jacksonville, Fl
    Thanks for the responses. I ordered the NTK NGK 24302 and have installed it. I got the FAST connector from FAST and installed it. I still get the Actual AFR of 0.0 and and O2 sensor fault. Could the melted connector have shorted something that would have damaged the XFI computer?
  8. RonnieW
    RonnieW Member
    Oct 21, 2009
    Jacksonville, Fl
    I was just going to splice the wires but found out the O2 connector supposedly has a resistor etched in it.
  9. fabr
    I have no answer on that. Will be interested in that info though.
  10. RonnieW
    RonnieW Member
    Oct 21, 2009
    Jacksonville, Fl
    Me too!
  11. RonnieW
    RonnieW Member
    Oct 21, 2009
    Jacksonville, Fl
    In case this helps someone else. My problem with new sensor not working was that I did not use 2 wires from the ecm because they looked as though they dead ended when I cut my burned connectors off. I reconnected those and all is well now. Those 2 wires actually go to the built in resistor in the O2 side connector. So all 7 wires from the efi ecm have to be used.
