o2 sensor code, no start
Discussion in 'FAST Support Forum' started by waybad1, Oct 21, 2017.
  1. Fastnofast
    Fastnofast Member
    May 16, 2017
    You can also check the continuity of the ground wire of the fast harness between the battery and fast ecu with an ohmeter.
  2. waybad1
    waybad1 Member
    Jan 22, 2012
    Ventura CA
    I am definitely going to go over everything again to make sure. Everything power and ground
    related. I dont want to send the ecu and handheld in until I am sure everything is ok. I know I
    have battery voltage or close to it to the handheld, pink wire and ecu but the handheld still
    reads 11.5 volts. I would assume I would notice 8.8 volts when cranking listening to the engine
    turning over?
  3. Fastnofast
    Fastnofast Member
    May 16, 2017
    Ecu won't let you start engine under 10volts. 8.8 is far too low. Check as i said the ground wires with a multimeter.
  4. waybad1
    waybad1 Member
    Jan 22, 2012
    Ventura CA
    I'm just saying if it really only has 8.8 volts cranking you would think the engine
    would drag. It just seems like a false reading. Checking everything now
  5. kevin87turbot
    kevin87turbot Member
    Jul 27, 2012
    Ripley, MS
    What error code pops up when the ECU light is flashing...just the O2 sensor code?
    Does the engine fire up if you spray starting fluid in the throttle body?
    Usually, if an engine is backfiring during cranking, then there is a problem with the timing...
  6. waybad1
    waybad1 Member
    Jan 22, 2012
    Ventura CA
    Right after it died I checked for spark and carb cleaner for fuel. At that time there was an o2 fault that I cleared and tried to start it. It set the code at least 10 while I tried to start it. It is not setting that code now. If the ECU has failed internally is it possible for it to send bad enough commands/signals to cause a no start backfire scenario? The way it happened so fast is real weird. Running perfect one second and stall the next.
  7. Fastnofast
    Fastnofast Member
    May 16, 2017
    Unfortunetly yes it is possible. And yes 8.8 volts or internal damages can turn the ecu into a crazy machine !
    To be sure, can you check wires ? It is too simple and let you focus on the bad part
    You can play with this all you want.... But, you have correct voltages everywhere else. The ECU system is malfunctioning. As long as it isn't repaired, It will not start your vehicle. This no start issue is due to a damaged internal ECU component and scrambled data. Don't let anyone goad you into wasting your time. The sooner you do the RMA, the sooner you will again have a known working system. Actually, it will be better than new due to the new software update FAST does after the repair. The O2 code you originally got was due to a loss of power to the O2 sensor. This is an occasional problem that happens to some EZ EFI 1.0 installs -usually where ignition boxes have been connected as yours was, and caused ECU damage over time from electrical interference.
  9. waybad1
    waybad1 Member
    Jan 22, 2012
    Ventura CA
    Just got the RMA #. Thanks A A for you help and everybody else's suggestions.
  10. Fastnofast
    Fastnofast Member
    May 16, 2017
    You should also check your wires and everything while you wait for your fast ecu. Because if it comeback repaired you would not cause new damages when it will be reconnected.
  11. waybad1
    waybad1 Member
    Jan 22, 2012
    Ventura CA
    I just received a call from Greg at FAST. They did find a bad chip in the ECU. It has been repaired and tested on
    a running engine. NICE. Great customer service.
    You should be ready to input your settings again and have your vehicle running great again with no further problems - once you get the ECU back. To your credit, your ECU will also now be ready for the newer upgrade to a color 1.0 handheld - if you decide to get one.
  13. waybad1
    waybad1 Member
    Jan 22, 2012
    Ventura CA
    I asked and they were nice enough to offer it to me for $249.00.
    Sounds good. The new handheld offers not only easier control, but a new look with improved ability to control warm and cold start fueling - for improved starts.
  15. Fastnofast
    Fastnofast Member
    May 16, 2017
    Before reconnecting your ecu i would recommend you to check ground and power related. it would be too bad to breake it again
    Clean the wax out FatsoFat. He has already corrected the problem and doesn't require un-needed aggravation. If there is another problem, he'll need the ECU connected and running to find it. Now, go breake something there at home in France. Your computer has a virus.
    waybad1 likes this.
  17. Fastnofast
    Fastnofast Member
    May 16, 2017
    Love it !
    You are awsome AA :)
    You are so funny !
    You make me smile :)
  18. waybad1
    waybad1 Member
    Jan 22, 2012
    Ventura CA
    I'm back with good results. Fast redid the ECU and the vehicle now starts and runs. No 02 codes now. I did notice the 02 ready light comes on much faster then before
    and it starts up and does not die at all like it had done before on occasion. Still not perfect but livable. I went over all the wiring again and put 3 toggle switches
    in the cab wired with relays to both msd units and the ecu 12 volt running off a second battery I installed. I also removed the Edelbrock Air Gap and installed an Edelbrock
    Super Victor manifold, wow what a difference. The idle is much smoother and the off the line accell is much smoother then before. You can feel that the engine is
    stronger. I was told by my off-road buddies I would lose some torque with the single plane. In theory that might be, but I feel it is stronger now.
    That's great to hear! Those buddies were wrong. You're making more power off the line now, throughout mid-range and top-end, than before - all by using the far less restrictive single plane Super Victor with its large plenum benefit of dampening cylinder pulses, and its much more equal runners. That's the great thing about using a TBI with the correct manifold. Your cylinders are now fueling equally. The benefit of low RPM torque, using a dual plane, only holds true when using carburetor venturi - that do benefit from cylinder pulses in the intake.
    Now, all you need is to just tweak your F/A numbers and timing for best performance - then tweaking enrichment if you have the color handheld.
    With the new intake, you should be able to run a few degrees more idle timing, and the F/A at idle and cruise may need some changes to optimize everything.
  20. waybad1
    waybad1 Member
    Jan 22, 2012
    Ventura CA
    I left the settings the same for testing 14.4 14.7 12.8 -3 accell. It feels good. Its funny the idle being smoother you can't hear the cam as much.
    I saw soot on top of all the valves when I had the intake off. Some cylinders more then others. I feel like it has been running rich the whole time
    I have been running it. The plugs are not black at all though
