PCV and IDF carbs
Discussion in 'Inglese Support Forum' started by Tom Hewitt, Apr 11, 2012.
  1. Tom Hewitt
    Tom Hewitt New Member
    Apr 11, 2012
    My engine builder connected a PCV to the manifold vacuum connection on my SBC IDF setup. I don't think WEBER IDF's are designed to have what is essentially a vacuum leak.:confused::confused::confused::confused:Am I correct??
  2. amick
    amick Active Member
    Jul 21, 2009
    Memphis
    Tom, is this one of our Inglese setups with the optional vacuum lines?
  3. Tom Hewitt
    Apr 11, 2012
    Pcv
    Yes- It has the under manifold vacuum lines combined at the rear of the manifold to provide vacuum signal to brake boosters etc.
  4. amick
    amick Active Member
    Jul 21, 2009
    Memphis
    Ok after checking into this some you are right. You should not be running a PCV valve with this setup.
  5. Tom Hewitt
    Apr 11, 2012
    Thank you
    Thanks for the PCV info...much appreciated
  6. amick
    amick Active Member
    Jul 21, 2009
    Memphis
    You're very welcome. If you need anything else just let us know.
  7. qabilan
    qabilan New Member
    Apr 28, 2013
    These carbs are commonly used in pairs, this makes the synchronization important,
    be sure to bring the high flowing carb down to the low flow carb. Then bring them both up to “proper” Idle speed.
