Timing strategy XIM
Discussion in 'FAST Support Forum' started by Caprimaniac, Oct 9, 2018.
  1. Caprimaniac
    Caprimaniac Member
    Nov 6, 2011
    Hello, hello.
    I consider switching to a ATI damper w/ Integrated crank Wheel or magnets. The trigger Wheels are 24x, for "AEM infinity and other aftermarket units..:"
    In the XIM instruction sheet I find "1 - 0 - 0 - 1 24 Pulse Dist. Plug 24X (Even, 1 cam)"
    Question is: what does "Pulse Dist. Plug" mean?
    AEM calls their unit a "distributor plug" because that's where you install the AEM when going to COP and of course they need a cam signal as well as the crank. If you are using a separate trigger wheel then where are you going to get the cam signal?
