Timming
Discussion in 'FAST Support Forum' started by 427snake, Aug 19, 2019.
  1. 427snake
    427snake Member
    Nov 18, 2013
    how to check the correct timing at the Fast Dual sync distributor when the engine is running
    Thanks Martin
    Ignition Parameters. Check the fixed timing test advance and match that number with the timing light.
  3. 427snake
    427snake Member
    Nov 18, 2013
    Hello Richard
    Thank you for your prompt reply
    Sorry for the weird questions but I'm not a tech guy
    the question is for me then if the timing light then me must show the number as in the fixed timing test advance entered? that's 20 with me as you registered it then.
    And do I have to activate the check for fixed timing test advance?
    many thanks
    Martin
    Move the distributor until the numbers match, lock down the distributor, uncheck the box.... done....
  5. fabr
    I think I'm correct that you can also change the commanded fixed timing number to match the timing light to achieve the same result if just a few degrees difference so far as the ecu is concerned. PLEASE correct me if that is not correct Richard.
    You can, by changing the Crankshaft Reference Angle in the software, but only if it's close to begin with.
  7. 427snake
    427snake Member
    Nov 18, 2013
    Thanks for the answer
    Has worked great
    Car is running and learning
    The next day we drove out a few kilometers at once and did not jump.
    Ignition is ok
    I'm going to measure the cables through to the fuel injectors.
