Why so many remote tunes all of a sudden?
Discussion in 'FAST Support Forum' started by Fastmanefi, Jun 23, 2018.
  1. Blown7
    Blown7 New Member
    Apr 7, 2011
    update I called FAST on Friday and verified with a tech that indeed my boxes were there and it will take a week or so to get an answer.
  2. 91Vette666
    91Vette666 New Member
    Dec 21, 2013
    Las Vegas
    When creating a XFI 2.051 tune for road and one for 1/4 mile track equipped with a 6speed manual, be it on a road or dyno, is it best to tune in 3rd or 4th gear?
  3. Blown7
    Blown7 New Member
    Apr 7, 2011
    Well a Mr. Rob called me from FAST and said my XIM was fine..... But the XFI had a full memory dump... whatever that is. So they fixed it and ran the units on their test engine and said I should have my boxes back by Tuesday or so.
    FAST's customer service is great. Now what the hell is a memory dump and how can you tell if you have one????????????????
    When you are connected to the ECU if you go to View/Display ECU Configuration all the numbers will be blank or zero.
    Blown7 likes this.
  5. Blown7
    Blown7 New Member
    Apr 7, 2011
    Ahhh....Okedoeekee.... So how does a memory dump occur?
    And how do you repair it?? Or is that something only FAST can do??
    A memory dump is a BAD THING. It means you have lost the "boot code" stored inside the ECU's non-volatile memory. I have seen this happen when there has been a power glitch, or if people turn off the ECU by removing the main power which should be directly connected to the battery and never turned off. It cannot be fixed in the field. You must send the ECU back.
  7. Blown7
    Blown7 New Member
    Apr 7, 2011
    Ahhh I know a bit about boot loader code, if they only said that. But then again there must be a way to store and reload the code in the field. I do it all the time on the OEM PCM for my SRT and Trackhawk. A few different ways to load in given the chip makeup via Can, Nexus, or if it is a really old chip you'll have to use the BDM header on the board. The last one you have to open up the ECU. There is a load function thru the Flash function, Can't you get to the boot code thru that?
    BTW the boxes should arrive back home on Thursday the 15th.
    Maybe we can remote tune Friday if everything powers up properly??
  8. Fastmanefi
    Yes. The code can be flashed from the outside but you need a special routine and data file. I have done it once in the field because a very important car had to get going but it is not something the public could do because it's probably different for different ECUs. You'll be fine if your installation is correct.
  9. Blown7
    Blown7 New Member
    Apr 7, 2011
    Well Mr FASTmanefi... The boxes are back, installed and test run. Wideband O2, startup, and intial "Bogus Tune" works flawlessly. Now to find some time with you......
    A Big shoutout to the FASTTechnical Memphis Team. All repaired and at now charge.. even shipping back to me was FREE!!
  10. Fastmanefi
    Call me to schedule.
  11. Blown7
    Blown7 New Member
    Apr 7, 2011
    One more thing I forgot to mention from day one.. I use a Aeromotive rising rate fuel pressure regulator connected to the manifold pressure, I'm sure the fueling could get messed up if the FAST box isn't adjusted for that.
  12. Blown7
    Blown7 New Member
    Apr 7, 2011
    Thanks again Rich!
    I recommend this guy to anyone!
    BTW I found out what happened.. the engine did get that hot, I forgot to turn the electric fan on.... (separate switch)
  13. CWPottenger
    CWPottenger Member
    Nov 25, 2014
    Do you do tunes for the XFI Street systems? If so what info do you need and what is the cost for a tune file?
  14. Fastmanefi
    Yes I remote tune XFI Street systems. Call me for details. 209-247-6497
  15. Blown7
    Blown7 New Member
    Apr 7, 2011
    Just an update.. this is the second time this has happened but luckily I worked thru this before sending the boxes back to FAST a second time.
    For some strange reason the XFI had lost the entire calibration.. everything.. injector setup..all global parameters... even the engine cylinder selection..all .gone. From working great one day.. then the next day at start up nothing !!!
    I reloaded the file and everything is as good as new.
    I still haven't figured out why the XFI box just looses everything......
  16. Fastmanefi
    You might be killing the main ECU power rather than turning off the switched 12V. The main power to the ECU must be connected to the battery at all times. The switched 12V is the only way to turn off the ECU; and even then, you should wait until the main power LED goes off before turning it back on. That's about 5 - 6 seconds.
    I have run into this before with racers that have a main cutoff switch back at the battery but the ECU main power should go around that switch.
    Not saying that's what's going on but your symptoms are suspicious.
