Wiring question XFI 2.0
Discussion in 'FAST Support Forum' started by Russ67scode, Feb 18, 2019.
  1. Russ67scode
    Russ67scode Member
    Oct 6, 2016
    So just a question
    Is the only ground on the ECU connector “D” grey 16 pin for the injectors on the number 1 pin? Or should I have connect all the other returns to ground also ? See picture
    Thanks Russ
    Trying to figure out an injector problem
    There are no other returns. Injector drive ground the injector output. The injector harness provides the 12V to all the injectors.
  3. Russ67scode
    Russ67scode Member
    Oct 6, 2016
    Thanks Russ
  4. Russ67scode
    Russ67scode Member
    Oct 6, 2016
    Just an update. I had flushed all of the fuel system I thought well enough But found a bunch of trash in the little “bucket” filters clogged !
