XFI Creep Wiring - A13 Used - Can I use A12??
Discussion in 'FAST Support Forum' started by Justa6MB, Sep 18, 2017.
  1. Justa6MB
    Justa6MB New Member
    Nov 23, 2016
    Newbie XFI. Been doing lots of reading on the subject. Creep isn't working and wanting to clean up trans brake wiring. Have read using A13 as a ground source has helped fix some issues. However it appears A13 is being used, or at least there's a wire leading to the kick panel in my Buick GN. Can I use A12 as a ground source instead? A13 shows Distributor Ground. A12 is Main Power Return (Ground). And can I feed both the trans brake switch and the creep button off of the same switch - A12? Or should I be using another main power return high current pin ground for the 2nd switch? Also I've got the launch switch T'd into my AMS500 boost controller ground activation. Is there a better way to do that?
