XFI DASH/DATA LOGGER wiring diagram HELP!
Discussion in 'FAST Support Forum' started by Diego Garcia, Aug 29, 2017.
  1. Diego Garcia
    Diego Garcia New Member
    Apr 27, 2016
    Buenos Aires, Argentina
  2. Diego Garcia
    Apr 27, 2016
  3. Fastmanefi
  4. Diego Garcia
    Apr 27, 2016
    Thanks! I'm dowloading it, right now!
  5. Diego Garcia
    Apr 27, 2016
    Ok. I downloaded the software and read the instructions. There's no harness picture for reference. Do you know which is this connector function (see picture attached)?
    2.2.4 from the help section:
    The FAST™ XFI™ Touch Screen Dash/Data Logger has one RS-232 serial connection typically used for connecting to an aftermarket engine controller or GPS receiver. The RS-232 connection is on the back 28-pin circular connector and comes out of the harness on a 9-pin circular connector. For connecting to a device with the normal 9-pin DB9 connector, the purchase of the ECU connection kit is required. The 9-pin DB9 connector on the side of the dash is only used for pass-through communication and can not be used to connect an RS-232 device to the dash.
  7. Diego Garcia
    Apr 27, 2016
    I don't see your name, but I really appreciatte your quick answer, thanks a lot for your support.
  8. Fastmanefi
    Fastmanefi.com
    My name is Rich.
