XFI Sportsman - Hard Start When Hot
Discussion in 'FAST Support Forum' started by kiltedrunner, Jul 11, 2018.
  1. kiltedrunner
    kiltedrunner New Member
    May 29, 2016
    Canada
    Hi guys,
    I'm hoping that someone here can help me out. I have looked high and low to figure out my hard start when hot - but still having the issue.
    I have a XFI sportsman / EFI 2.0 throttle body on a mopar engine. The high torque starter spins the engine over very easily when cold, but when it's hot, the engine just barely starts to spin and then almost completely stops for a second, then cranks over slowly and finally fires up. I have dropped the spark table at 0 & 100% load below 700RPM to 0 degrees BTDC - this didn't help at all.
    I had a theory that it was my new hydraulic lifters bleeding down on one cylinder making high cylinder pressure... but just tonight the sportsman system crashed briefly while the engine was hot and the starter spun the engine super fast - without firing up... Shortly afterwards, I rebooted the XFI Sportsman and I ran into the same issue as stated above where the engine barely turned over (starter was labouring intensely).
    So now I believe it is the ignition control managed by the XFI Sportsman that's causing my grief.
    Any thoughts on this?
  2. kiltedrunner
    May 29, 2016
    Canada
    Oh, yeah and the engine starts very easily when cold. Fires right up.
  3. J.K.
    J.K. Member
    Is it possible the starter is on it's way out?
    My buddies car was doing the same thing. His is carb'd, but similar problem. Starter spins normal when cold and hard when heated. He replaced the starter and all seems good again. Just a thought.
    Low voltage to the ECU can cause all kinds of problems. As JK said, it could be the starter going bad and drawing excessive voltage when warm.
    Also check the main starter cables and engine ground from the battery for high resistance.
  5. kiltedrunner
    May 29, 2016
    Canada
    Thanks guys. I have a brand new starter with a welding cable running from the battery in the trunk to the starter. I'm worried that the cable may not be heavy enough. I'll check the draw at the battery and the starter while starting.
  6. kiltedrunner
    May 29, 2016
    Canada
    Thanks guys. So it turns out that my positive wire is unable to power the starter from the trunk. I have a 1 guage wire in place, but I found that it drops 3 volts from the battery to the starter under load!! I'll be mounting a 2/0 gauge welding wire in place to see if that makes the difference.
    Fingers crossed!
    Moomoo81 likes this.
  7. LnL
    LnL Member
    Nov 24, 2010
    Is your XFI power wire ran to the battery, or fed off the starter-end of that cable? Even the "switched" wire to the ecm needs full voltage - I've used a relay with a jumper off of the main feed wire, to assure minimum voltage drop
  8. kiltedrunner
    May 29, 2016
    Canada
    Oh yeah, I definitely have a direct positive wire from the battery to the ECM - I set it up that way from the beginning.
    I just bought 2/0 cable and solderable ends but haven't had the chance to install yet. Hope that helps!
  9. 91Vette666
    91Vette666 New Member
    Dec 21, 2013
    Las Vegas
    Just for fun check your Start Up Timing, would recommend setting those cells between 16 to 18 if it is higher than that.
  10. kiltedrunner
    May 29, 2016
    Canada
    Thanks for your reply 91Vette666.
    Do you know where I can make this adjustment? I'm assuming in the base table?
  11. 91Vette666
    Dec 21, 2013
    Las Vegas
    Yes, at the spark base table - the four cells to the far left at the Map (kpa) where the football is hovering at start only. I believe this should work for you, I was in the very same situation you were. I even put in a remote solenoid. But when I was at my wits end that's when I figured it had to be the timing at start and it was. I'm in the wonderful Las Vegas heat right now, car starts right up.
  12. kiltedrunner
    May 29, 2016
    Canada
    Hi guys, just updating this string.
    I did adjust the spark base table and that helped a wee bit, but the main issue ended up being a poor wire from the battery in the trunk to the starter, causing a voltage drop from the battery to the starter itself... super embarrassing... I ran a 0 gauge wire from the trunk to starter and the engine fires right up. No doubt though, the spark base table did help too.
  13. Dart67
    Dart67 Member
    Sep 12, 2011
    Jessieville, Arkansas
    Do you ALSO have a Separate Ground cable ran from the engine block to the trunk mounted battery.
    If not you need to...
    Also if this is a Big block MOPAR with headers you may need to add a heat shield of some type around the starter to keep it form heat sinking.
    I have gon through this and to me it sounds like a combination of both of the above suggestions.
    Herb "Dart67"
