XIM CNP with 60-2 wheel adapted to Buick V6
Discussion in 'FAST Support Forum' started by Turbobitt, Aug 8, 2017.
  1. Turbobitt
    Turbobitt Member
    Nov 14, 2010
    Thought I would share this pet project. Wanted to see if I could clean up some starting issues with my stock 3 pulse trigger by switching to a 60-2 wheel for more resolution during low speed cranking and start up. I custom designed the wheel and sensor brackets myself and had everything coated. I integrated a trigger wheel set point at TDC and cam sync to make it easy to line up and install without guessing where the wheel position is.
    So far my impression is a vast improvement. Could not have done this project without the help from Lance.
    Allan G.
    Jerryl likes this.
    Very cool and nice work. Love the black.
  3. fabr
    nice!!!!! I love good fab work!
  4. Turbobitt
    Turbobitt Member
    Nov 14, 2010
    Can't take to much credit for fabricating, all of it was from CAD to laser cut parts.
    I do have a newer design I think is pretty slick with an integrated ring gaurd and sensor mount. This new design is also a little more flexibility with mounting options at various depths by simply just changing spacers. I'm a little surprised no one has had a similar idea. All the 60-2 aftermarket mounting is just carryover designs from the traditional flying magnet crank trigger wheels. I wanted something a little more safer with a flying sawblade under the hood.
    Jerryl likes this.
  5. Fastmanefi
    If the ring guards are Ferris this will affect the sensitivity of the pickup signal. Also you would need a way to adjust the sensor mounting to accommodate other engine configurations.
  6. Turbobitt
    Turbobitt Member
    Nov 14, 2010
    I made this specific for Buick, wasn't intending on a universal fit. Was happy to just have a working copy. And yes I know, its made from aluminum, not magnetic material.
    AG.
  7. fabr
    CADding is just a modern way of fabbing.
  8. Jerryl
    Jerryl New Member
    Nov 9, 2016
    Houston
    You build some of the nicest stuff out there! :cool:
  9. Juan89
    Juan89 New Member
    Jul 16, 2015
    Did you need special firmware for the xim ?
    I do not see switch setting for this combo in the xim manual.
    Juan
  10. Turbobitt
    Turbobitt Member
    Nov 14, 2010
    No special firmware. There are 2 manuals in the Help file but only one shows the DIP switch settings for the different strategies.
    AG.
  11. Juan89
    Juan89 New Member
    Jul 16, 2015
    OK, thanks.
    Juan
